How can I make a gear profile at the end of a plastic tube
amccaffrey-2
I have a plastic tube, inner diameter 19.0 mm and the wall thickness is 3 mm. I wish to make a circular gear profile. Can anyone tell me how I go about this?
I'm using Creo2.
Oddly enough your request is also a simple version of the crown gear.
This is a sinusoidal sweep using "trajpar" in the sweep sketch.
You can do something similar with evalgraph().
Creo 2.0 commercial version attached.
hint: when you modify the sketch in the sweep feature, take a look at the sketch's relations.
If you are looking to make gear that will envelope that tube you can use trace curve.
Here is tutorial that shows that. Its not in english but you will understand just by looking at video.
Modeliranje zupčanika na osnovu linije sprezanja - YouTube
Your talking about a crown gear at the end of the tube?
amccaffrey-2
(To:TomD.inPDX)
My apologies guys. I gave some misleading information so I'll start again!
I have two tubes that I wish to interlock end to end using a sort of gear profile so that the two tubes will revolve as one over a rod. It doesn't have to be a proper gear profile, just a series of 'vee' shapes but the profiles will be proud on one half and inset in the other half. When assembled end to end the proud profiles of tube 1 will sit in the inset profiles of tube 2.
