Creo 2.0 m080
I am working with a model that contains a blend. The sections are offset from previous sections. When I show the annotations of the feature on the drawing, the offset dimensions don't show. Has anyone run into this before? How can I show the dimensions without creating the dimensions in the drawing.
I guess that the problem can be cause by section. I suggest you to create simple model+drawing and do a test. In case that you will be able to reproduce the problem, please upload your data using How to attach file when you Reply to a discussion.
I tested blend feature in CR2 M070 and was able to display blend dimensions in drawing view.
MH
MH
