I have the 3D sketch done using the Sketch tool,It is the type PRO_CURVE type has mulitple lines and arc in it.
I could able to get the geometic data of each item in my curve.I have to do the same by doing the offest curve of my orginal curve.I could not able to get geometic data if i do the offest from Edit>Offset option.It is a datum curve instead of the sketch.
If i do the offset with Sketch>Sketch Offset option i could able to get the geometic data as i required.I would like to know is any body done offset the 3D sketch using any API's?
With regards,
Kishore V
