How can identify C0, C1, and C2 continuity condition in this product?
Which is the best analysis tool for analysis surface?
Hi Vishal,
Take a look at this You Tube video, I believe you should be able to select a surface when you are performing the Curvature Analysis.
I hope this helps some or gets you pointed in the right direction.
Amit
Thanks Amit.
I have understood in curve. How can i check the same in Surface? My concept is not crystal clear in the surface.
How can i identify curvature continuity condion for this surface case?
Hi Vishal,
Take a look at the following tutorial video from the Learning Exchange:
Using Shaded Curvature Analysis for Surfaces
Also, do a search using the curvature keyword to find other videos.
Amit
Tutorial: Evaluating Connections in Technical Surfacing
http://learningexchange.ptc.com/tutorial/3442/evaluating-connections-in-technical-surfacing
