I'm stuck! I am trying to use Creo Distributed Batch to generate renderings of CAD Objects from Windchill. When accessing objects in a Windchill workspace Creo Distributed Batch generates a TTD file that includes a <SECURITY> tag. The contents of the tag enables the Resource Service (worker) to access files in Windchill a workspace or the commonspace through an anonymous URL. The <SECURITY> tag is temporal and quickly expires. See the attached file for a sample TTD file sent to the Service Manager. So, . . .
How do I generate the contents of the <SECURITY> tag in the Creo Distributed Batch TTD file?
A few associated notes.
Creo Distributed Batch requires a user to authenticate to Windchill using a username and password. Form Based Authentication (FBA) is incompatible. This is unlike Creo Parametric, View, Illustrate, Schematic, etc. and the Windchill workgroup manager. Additionally, Creo Distributed Batch authenticates through a protocolAuth URL.
please contact PTC Support. I think Community users will not help you to resolve the problem.
