How to aligning dimension in Pro-E drafting ?
pjaguar
align.png     Hai every one, i like to align this dimension in pro-E Drafting but i don't know how to do this.
KenFarley
(To:pjaguar)
If by "aligning" you mean make the leaders line up with each other, you could try moving them around and any dimensions which share a leader will snap to each other. What I do is create snap lines, then move the dimensions onto the lines, etc.
There is an align function. Right in the Annotate tab.
Mahesh_Sharma
22-Sapphire I
(To:pjaguar)
As Don suggested you can use Align dimensions from Annotate group OR select dimensions > Right Click > Align dimensions
You can also add snap lines around a view - this is my preferred way of working.  These allow you to arrange your dimensions evenly, but do not show when you print the drawing.
Typically I set the first line 15 mm from the view boundary, and space the lines at 12 mm intervals.  I generally create more lines than I think I will need (usually 6 in one location, but maybe up to 10 for a complex part or as few as 3 for a small detail view).
psobejko
(To:pjaguar)
You can also select the dimensions, then right-click and select "Clean-up Dimensions".
This will launch the tool to create snap-lines which align the dimensions.
Mahesh_Sharma
22-Sapphire I
(To:pjaguar)
Prabaharan,
There are multiple good responses to your query. Does any of these help you?
