Hi all,
I am trying to use custom hole chart in Creo 7.
Everything is OK except that the call out of standard holes are not attached to the cosmetic threads.
Fig.1
According to our company standard, it should look as in Fig.2
(the arrow always points toward the center, and it is attached to the thread)
Is there any way to achieve this?
Fig.2
If you have any ideas, please let me know. Thank you so much!
I have not tested this on a cosmetic thread surface but it may work,
Try this in the part model
1) open the note's properties in the model
2) unplace the note
3) place the note, selecting normal leader option, and attaching the note to one of the two half-cylinder surfaces
Thank you for your answer.
It is possible to edit attachment every time, but it is very inconvenient.
Actually I am looking for kind of an "automatic" solution, like a config option or drawing option, or a change in .hol file.
It seems that others have the same problem and PTC does not really care...
Two options come to mind to avoid manually updating the leader for each hole. Both are similar in approach.
Use the copy/paste functionality to paste a "correct" version of the hole with note. This would require the creation of a reference model with the note per your spec. You would then retrieve that model to get the hole into a given model.
You could also try using a UDF for your hole(s) where you have modified the leader attachment to your specification. You can then place the hole using UDF functionality and the note should be as defined in the UDF.
Thank you for the suggestions!
I actually tried UDF before this, but standard hole's UI seems more intuitive (and creating holes with it is faster), so it would be nice if we can use standard hole directly. Moreover, now that PTC introduced multibody, every time we place a UDF feature, there is one more reference to select (the body). It also seems to me that copy/paste is not simpler.
I will find ways to make it more convenient to create hole features with UDF or copy/paste. Thank you!
Unfortunately this is how Creo (Pro/e) has worked forever and (so far), no one at PTC has been willing/able to change it. There are a couple of open product ideas about that exact issue. Go vote them up!
Thank you!
I upvoted both of them.
Hope that PTC does something about this soon.
Try this:
I am sorry I was not clear enough in my question.
Actually I am looking for a way to do it automatically, so that I don't need to edit the attachment every time.
Still no hope though...
I could not find a setting that affects the default note style for hole tables. It would be nice if they would add that to the detail options.
The only way I know of to speed this up would be to create a mapkey.
Life would be much easier if PTC care about what are discussed on PTC Community 🙂
Thank you so much,
