hi,
in WF4 we had a provision of hiding annotations using layers (when we needed specific annotations to be desplayed, others could have be added on to a new layer and the layer could have been hidden).Now in creo when i try to do the same i'm unable to hide annotation in layers.
Is there any way to do the same in creo.....
WOW, no answer to this question and it's now 2018! Running into the same issue in CREO-3.
What annotations exactly are you trying to hide?
You can turn annotation display on/off with the toggle in the view tab, show, the icon that has a little yellow sticky with an arrow leader attached.
In the annotations tab, select all items in the annotations tree, RMB and remove from state.
I'm using CP4 M040, but should be true across the board.
This is the answer!
