Hi there,
I like to dimension the position tolerance of optics center to the hole center. But the tolerance zone is a square zone of +/-0.05 in x& Y, and not the diameter zone. Any idea how to do it ?
I think I might look down on the spring and create a sketch with a projected edge to place a datum point in the center by whatever method you use to find a center of the projected edge such as tangent arc if needed. If you extrude a feature from the sketch (to be hidden later) it will create an axis for you.
You might also be able to create tangent planes on either side and use relations to place planes in the center, from which you can derive an axis.
Most likely, the dumb solid already has the appropriate center, in which case the coordinate system is likely already in the right location to create datum planes and axes from. The Data Doctor might be the appropriate place to add these features so they are related to the import feature.
Bingo! The method I was going to suggest until I was Ninja'd!
