How to reduce &fam.inst.param.name in 2D region?
rvlasic
Dear all,
I would like to ask you about some possibility to reduce the name of parameter in 2D region on drawing.
In the Family table in a Part there is a Feature Parameter named “LENGTH”
I would like to show this on the drawing. So I will use the 2D Region. For showing the Name of parameter I will use “&fam.inst.param.name”. But in the cells is showing “LENGTH:FID_1354”.
Is there some possibility to show only “LENGTH” without “:FID_1354”?
For example:
For showing number of decimal places we use in “&fam.inst.param.value” sign “[.1]”. Exist something like this also for the name?
Thank you for your meaning.
Best regards
Roman
  • I opened konzola.prt
  • I moved relation from Initial section to Post Regeneration section (see combo box in bottom right corner of Relations dialog box)
  • I regenerated part
  • I verified all instances
  • I saved part
  • I opened trial.asm
  • I regenerated assembly (and assigned density, when asked)
  • I saved assembly
Now everything is in GREEN state.
MH
Martin Hanák
9 REPLIES 9
mender
6-Contributor
(To:rvlasic)
I have not tried this myself, but this may work:
In the region with fam.inst.param.name, use Repeat Region > Relations to make a local parameter 'myname', and a relation to drive it from fam_inst_param_name and do such processing as is desired (here, searching for : and getting the substring up to but not including the colon), and call out myname instead of fam.inst.param.name.
Give it a try?
I tested your suggestion without success.
Working solution:
  • in generic model, define Post Regeneration relation ... MYLENGTH=LENGTH:FID_1354
  • remove LENGTH:FID_1354 parameter from family table
  • add MYLENGTH parameter to family table
  • verify all family table instances
MH
Martin Hanák
rvlasic
(To:MartinHanak)
Hi Martin,
thank you for your help.
I have to say... I know this way. But here i have another problém:
When i done this and verified instances=> the part has the GREEN sign. If I open the part second one (some instance) it isn't in GREEN but has a YELLOW sign.
And the same thing is by using the part in assembly.
and the second thing: there is the critical warning:
Relation LENGTH=LENGTH:FID_1354 override family table values of instance D\:práce\konzola1<konzola>
Thank you for your reaction.
Best regards
Roman
PS: Sorry for my english
can you upload your model ?
See How to Attach a File to a Discussion Reply document describing upload procedure.
MH
Martin Hanák
FYI when I open instance of my test model, the semaphore light is YELLOW, too. Regeneration changes it to GREEN.
MH
Martin Hanák
rvlasic
(To:MartinHanak)
Hi Martin,
I am sending some example. is not the real model, because it is a company knowledge. But the problém is the same.
I know that aftere regen it is going to GREEN. But with using in a biger assembly ... i am little bit neurotic
Best regards
Roman
  • I saved part
  • I saved assembly
MH
Martin Hanák
rvlasic
(To:MartinHanak)
Martin,
thank you very much.
everything is GREEN and without any critical warning.
This is exactly what I need.
Thank you very much.
with respect
Roman
rvlasic
(To:mender)
Thank you Matthew,
I tried this, but do not go.
I create the relation LENGTH=fam_inst_param_name, but I am not sure what does mean "do such processing as is desired(here, searching for : and getting the substring up to but not including the colon)
And how to call out the LENGTH?
I tried, but all values was hiden.
Thank you very much
Roman
