Hi All,
How would one parametricly show the quantity of one component in a BOM repeat region in a separate note at the same time on a drawing? FYI, The part in question not part of a pattern. Just assembled multiple times in different locations.
For instance if I had work instructions on a drawing sheet and wanted to say
Notes:
1. Apply lube A458-63 to 89568-456 quantity x before torquing to 30 ft lbs
How would I call out the quantity for a part used in a assembly in a drawing note parametricly?
Thanks for any help you can provide,
Don Anderson
BOM parameters are not available outside the BOM.
Lube would be entered as A/R quantity in our BOM as it would be a bulk item.
We put both item number balloons on the item that gets the lube.
Our note would say: Apply lube A458-63 to 89568-456 before torquing to 30 ft lbs
