How to set default normal dimension to default basic dimensions in sketcher
sdara
How to set default normal dimension to default basic dimensions in sketcher.jpg
Dear Sateesh Dara,
I think this is only available after exiting the sketcher.
Select the dims and edit their properties.
Sorry, it is not in the sketcher.
Gerald
yhao
(To:sdara)
It may available in drawing.
Marco_Tosin
(To:sdara)
This is not the right section to post your request.
I think Creo is the correct section.
Ryan Kelley‌ can move this discussion for you.
Marco
Thanks for notifying me Marco Tosin‌, I've moved this discussion into our PTC Creo‌ product community.
