How to sign off(values) in drawing
JAK
I created assembly by using coordinate systems(cs).So it having (+) and (-) values.When i try to create drawing,it shows (+) values and (-)values.I need show values,So how to sign off the values in drawingCapture.PNG
Mahesh_Sharma
22-Sapphire I
(To:JAK)
akeerthi,
Check config option show_dim_sign.
JAK
(To:Mahesh_Sharma)
It dosent consider that config..Already i checked that one.It always show (+) and (-) while SHOW_DIM_SIGN="yes" or "no"
JAK
(To:JAK)
please anyone know the solution of that,tell me.its an urgent.
