How to use attach to harness command in Creo Cabling 2.0 ?
When I select a component to attach to harness it showing "component is not referencing any location." ? How to do that ?
Ajay
Ajay,
Run the network through a csys, point, or axis on the part you want to attach then use attach to harness.
jef
Hello Jeff
Passed the network through the axis of grommet but its not working.
Is there any thing else i have to take care of??
Ajay
Ajay,
I just tried it about half a dozen times. I noticed I had to really make sure I was on the additional part's axis. A couple of times it wasn't. It was confirmed by showing up on the flattened harness.
jef
