For instance, I have a collection of parts that are always grouped together but are not a subassembly. Wildfire 4 and before allowed you to create an UDF of the assembly which could then be used in other assemblies by inserting the UDF. I don't see the option in Creo to place a UDF in Assembly mode. Has PTC renamed this feature to something else?
Found it. There is a small icon at the top of the Get Data ribbon called User Defined Feature. This allows you to navigate to the location where the assembly UDFs are stored and install the assembly of parts to your assembly.
Don't forget to mark your answer as correct for those who may search on this topic.
