Pls help me how to use UV curves,Extrapolate,Merge & split curves in IDD and its functions.
UV curve will allow you to create curve on surface in IDD Mode.
Extrapolate: To extend surface, Select surface > Extrapolate > Select edge of surface and drag.
Split curves: It will split a curve in segments referring the location defined on curve to split, it can be an edge or curve.
Merge Curves: It will merge segments of adjacent curves.
