Import/Export STEP file naming and other oddities
SteveBarnhart
Hi all,
I've been importing a number of .stp assemblies into Wildfire 4 lately and I'm wondering why ProE creates an extra assembly level on import. For example, if I have a 1001.stp (assembly) it will open as 1001.asm containing 1001_asm.asm. The 1001_asm.asm contains the downlevel parts, so the 1001.asm seems redundant.
Is it a setting in ProE or is it the way the .stp was generated?
Also, when I generate .stp files of anything that has acrossection defined ProE seems to create a surface feature block between the cross-section and component boundary. The feature is called "import feature" when I reopen the .stp in ProE and is assembled at the top of the model tree. Any way to get rid of this when generating STEPs?
Thanks!
Ok, I solved part of this - the surface "import feature"was createdsince I had shells selected in addition to solids. Solids only = no strange features for cross-sections.
Also, for exporting .stp files, I found I could control the names better by using the step_config.pro option export_3d_force_default_naming = yes. Otherwise, I was getting suffixes added to every component name.
I still would like to know why ProE creates a redundant assembly level when it opens .stp assemblies.
If the original part/assembly was from CATIA, they may have created the
extra ass'y there.
CATIA has 'part' and 'product' models. Our customers usually export the
'product' to us even though it may be a single part.(???)
The incoming .STEP file comes in as an assembly, with the top level
including only a csys (as a transform) to airplane position.
I think you may be able to tweak the STEP import in config.pro to
eliminate some of the problems...
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
Is the 'step_config.pro' a special config file or just a standard
config.pro that you've created with only the STEP options? Can I put
the 'export_3d_force_default_naming = yes' in my regular config.pro?
Doug Schaefer
LinkedIn
