When I go to the Pattern Menu in Modeling, the default pattern is "Dimensions". Since I mainly use "Direction" or " Axis" , is there a way to edit the dropdown to reflect this?
I don't recall an option to set the default.
I use axis patterns mostly, so I made a mapkey to choose axis. In my case, I also set the degrees to 180 and made it for only 2 patterns. It seems to save a lot of clicks.
I also made one for reference patterns, it requires no clicks if I pre-select a feature that references another pattern.
Hi Bob,
No, there isn't an option to change the default pattern type. You can create a mapkey that starts the pattern tool and changes the type.
Amit
Hello
try to googled: "creo parametric hidden config". Maybe exists some hidden config options for this.
Have found: RETAIN_PATTERN_DEFINITION (hidden)
Don´t know how it works, but maybe it can help...
This option is obsolete and has been removed. It will not work.
Amit
