In the Schematics, how the difference between the straight and flexible shape type of linestock , is determined by one parameter?Which one?
Assuming you are intending to drive Spec Driven piping then first you will require a flexible stock in the catalog
You will then need to add to you pipe group the parameters
The value of the parameters need to correspond with the linestock in Piping design.
thanks, Jim
