Inspection dimensions and notes
DonSenchuk
7-Bedrock
In the properties of each dimension one can choose to make that dimension an Inspection dimension with the racetrack around it. Is there a way to do the same thing with Notes or GTOL Control Frames?
Don Senchuk
mcestnik
(To:DonSenchuk)
Was this question anwsered? I am dealing with the same issue.
Matevz
