When Making an assembly in Creo 2.0, from where I can check the interference betwen different component in the assy?
In SolidWorks it was called as Interference Detection, I don't know Creo have this kind of feature or not?
Analysis>Global Interference...
there is Search option in the right top side..that would also help you to find the command you are looking for.
and if you are using Creo 2.0 M090 and above the ..in the search option just enter your solidworks command..and Creo 2.0 will direct you to and equivalent command.
