Intralink Java question
lylebeidler
I'm coming up against some limitations in my intralink scripting (we're on
3.4) that are caused by the Java version being at 1.4.2. Is it possible to
upgrade the version of Java that Intralink uses, even if only to 1.5?
Thanks.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Hi Lyle -
I know what you mean about finding a pre-1.5 JDK.
> I’m coming up against some limitations in my intralink scripting (we’re
on 3.4)
upgrade
A few years ago, I was able to write my Java code on a v1.5 JDK but
specify
v1.4 as the target runtime environment. Are you able to do that?
You should be able to set this option in your IDE if you're using one. If
not,
the javac option is "-target 1.4".
|+| M a r k |+|
Mark Stallard
Rapid Response Development
information Solutions
Integrated Defense Systems
Raytheon Company
(business)
+1.978.436.6016
(cell)
+1.617.331.5443
(tie line)
239.6016
880 Technology Drive
Billerica, MA 01821
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
On 03/29/11 10:38, Lyle Beidler wrote:
> I’m coming up against some limitations in my intralink scripting (we’re on 3.4)
> that are caused by the Java version being at 1.4.2. Is it possible to upgrade
You don't specify which build of Ilink 3.4 you running however 3.4 M070 uses
Java 1.6.x I believe.
You can upgrade the jre in the Intralink install however you will find that
some items in the interface that will no longer work. I know this because I
tried it several times. The upgrade is simple:
1. rename ptc's jre directory to jre.original
2. unzip the 1.6.x jre runtime
3. rename the jre1.6.0_24 directory to jre
4. try it
> Thanks.
> Lyle Beidler
> MGS Inc
> Denver PA 17517
> 717-336-7528
> Fax 717-336-0514
> - <">mailto:->
