I found there are new possibilities for sheet metal users as from Modeling version 19.0 not to show the chamfers on a flat view by using the following settings in the shopfile. (this info comes from PTC case CS183661).
(sha_set_flat_sheet_border_show_inner_contour nil) to switch chamfer lines off (this suppresses only normal chamfers, not the chamfers of machining features)
(sha_set_flat_tool_show_boundary nil) – This should hide the chamfer on the machining features.
but is there also possibility to set these settings for Basic Sheets users?
I think this is a real basic setting that should be available for all Modeling users. not having this option already caused tons of sheetmetal parts turned into scrap because holes were made to big.
PTC, think about the environment!!!
