Is it possible to assign an overall density for a sub-assembly?
jgfrankusa
Pro gurus:
Happy Friday to all.
I have a Circuit card assembly in my top level assembly which weights about
.5 lbs on a scale. Pro/E assigns a default value of 1 to all the
components on the board which will mess up the top level mass properties
calculation. Is possible to assign a spcicific density value to the entire
CCA and tell Pro/E to ignore the sub-components on the PCB?
Thanks in advance for your time and help.
Frank
Yes,
Edit > Setup > Mass Props
Change the 'Source' pull-down menu from Geometry to Geometry and
Parameters
Pick the Edit button
Enter the mass in the appropriate field.
