If I'm using restricted parameter values for something like drawing numbers. Is it possible to make only the unused values available for new drawing numbers?
For example if I list 100-150 for the available drawing numbers and I have assigned 100-105 on previous drawings. Is it possible to have those numbers removed from the list of available drawing numbers? So that when I create a new drawing the only options that would be available would be 106-150?
Nope, not with restricted parameters. The only way I can think of is creating a custom J-Link program that is automatically doing parameter value validation.
Since it is a manual process to change the range of valid values for a restricted parameter, you probabaly shouldn't use restricted parameters for ranges that need to change.
