Hello all! I've tried googling my solution but to my disdain nothing has appeared.
For some university projects I'm working on them at home on my Academic Creo version; however some of the projects call on using a that my version of creo does not have. Is there a place where I can download these templates?
Example: I need the a-h-3-views drawing template for a drawing of an assembly that I'm working on. Where could I find that particular template? Thank you!
Drawing templates are usually company or in your case university specific. It's possible your instructor has the template available for you.
do drawing template by yourself . I think this is the quickiest way how to finish your work.
MH
Hello jorge guevara
save a copy of desired format size and modify it als you wish. (As MartinHanak wrote.)
l think it´s it not possible to find 100% perfect format on the internet.
Just take some inspiration from internet and drawings of colaborating companies.
Milan
Think there is no better explanation than Stephen Williams ´s.
Think it should be marked as correct answer in order to help other users.
Thanks Stephen. It turns out that the instructions had unwritten corrections to them; the template that we were supposed to use was a template we had already created earlier this semester. Thanks for your answer though!
