Is it possible to print on a roll?
rvanveerdeghem
9-Granite
Does somebody know if it is possible to print on a roll with a plotter? I want to be able to print a complete wire harness with a scale of 1:1. Therefor I want to print this on a roll paper like a banner. For instance the size can be something like 3000x841mm. Is somebody been able to do such thing?
thanks
Ruben,
yes, it is possible. Create drawing with variable size 3000x841mm and print it.
MH
Martin Hanák
Ruben,
MH
Martin Hanák
I am sorry my reply is related to Creo Parametric, not to Creo Elements/Direct.
Martin Hanák
