Is it possible to rotate an surface edge around an axle? If not - is there any workarounds?
hnyström
Is it possible to rotate an surface edge (3D) around an axle?
Is i possible to rotate anything else but a sketch?
There's no direct way to do so, but you can create the geometry with a variable section sweep.  I covered this at MCAD Central a while back, check out this threadSample Creo 2 part in this post, full explanation starting in this one.
LinkedIn
StephenW
23-Emerald II
(To:hnyström)
What kind of output are you trying to get? For simple rotation about an axis, you can use pattern. Copy/paste the edge to get a copy, then use axis pattern.
I'm trying to create a revolved surface from a 3d edge (not 2d sketch).
In Rhino it is not an issue, it just works.
LinkedIn
Thanks a lot!
check my model created in CR2 M070.
MH
Martin Hanák
