Is there a way to add a lip to a thickened surface model?
nweston
So I'm creating a USB case for an assignment and I'm currently attempting to add a uniform lip to the various parts so they can slot together. I did the front edge by just extruding a cut away but the top edge can't be done this way as it curves in different planes. Any suggestions?
PGbqEY8.png?1
VSS or Swept Blend will work.
Offset surfaces will work too.
WayneN
3-Visitor
(To:nweston)
I would make the lip before thickening the part. Use the edge of an offset surface for a trajectory and create a variable section sweep that uses it. Or maybe add curves connecting the edge to the existing surface (like a ladder) and use a blend. In both cases the surfaces would have to be merged before thickening. It's been a while since I used surfaces, so there is probably an easier way.
