Is there a way to prevent users from changing the arrowhead style on a dimension?
cstarnes
We have a user that just insists on using non-standard arrowheads, and all threats have failed to stop it.  🙂
Is there a way to hide the arrowhead type context menu, or a config or DTL file option to lock the arrowhead style?
there is no way to do this. The only solution is >>> interview with the boss <<<.
Patriot_1776
(To:cstarnes)
Obviously you haven't used ALL the threats.  If they won't comply, FIRE them.  Simple.
