Is there any plug-in to Convert step(*.stp) file to part(*.prt) file ?
AraviK1
Hi folks,
Is there any plug-in to Convert step(*.stp) file to part(*.prt) file?
aravik
Ravi,
you can open STEP file in Creo. During this step Creo creates part containing imported geometry.
Martin Hanak
Martin Hanák
Hi Martin,
part containing imported geometry means?
can we see model tree history?
