Until recently I was able to create a PDF in CREO 2. Using the Export setup. Not sure what happened. Now when I go to create a PDF nothing happens and I receive no errors. I'm using Adobe reader 11. Has anybody else ran into this. If so how do I fix it?
Thanks Steve
look into trail file to see if there is some info concerning PDF export.
MH
Try a different printer. CutePDF is a good recommendation, maybe it can solve your problem.
