Hello~~
I have couple suggest about Lathe function of Creo manufacturing, please refer to below suggestion, thanks!!
Mark Rao
訊息由此人編輯:Mark Rao
Hello Mark,
your thread was cathegorized as Question, but it seems you made two suggestions how to improve the functionality.
Note that for such suggestions we have an extra section in the Community pages, called Ideas.
See this document with more information on the process.
The short form:
Gunter
Ad. 2 You can do that:
1. Create UDP.xml file with your parameters (TOOL_ORIENTATION, START_MOTION and END_MOTION)
2. set config.pro option : mfg_custom_tool_param_file <load_file_path>UDP.xml for example d:/ptc/setup/udp.xml
3. restart Creo. Your Tool Setup Dialog Box look now something like this.
4. Now if you copy parameters from tool you copy all parameters. ![]()
Hello Tomasz,
Thanks a lot for your help.
I have follow your procedure to set up Creo and created .XML file but I got failed information when I restart Creo, Do you know what?
Could you please provide .XML file to me for reference?
My e-mail= -
Have a nice weekend!!
Mark Rao
Hello Tomasz,
Thanks for your sharing and I can seem the "User Defined" dialog of Tools Setup window. But I still have question about parameters copy, could you please let me know how to set up config.pro then "Cut data" parameters can automatically copy to sequence parameters window?
I have set up "mfg_param_auto_copy_from_tool" of config.pro for "ALL", but that "cut data" parameters still can't copy to sequence parameters window.
Thanks so much
Have a good day!!
Mark Rao
Reffering to your question:
If you set any value in CUTTING DATA box it works well. I don’t know why doesn’t work if here is empty.
Hello Tomasz,
I could copied parameters to sequence from tool cut data and user defined, because I forgot store user defined parameters in each tool. My question was resolved, thanks a lot for your answer. Thanks again.
have a good day!!
Mark Rao
Hello Tomasz,
This problem was fixed out, because I forgot click "Apply", sorry!!
thanks for your support!!
Have a good day!!
Mark Rao
