Layouts and Variants
JWayman
Good morning.
I have a reasonably complex assembly that is driven by a skeleton/layout
combination. When I change the value of one of the parameters in the layout,
the whole model changes accordingly, right through the model tree, as
expected. So far, So good.
Now, I have one product based on this assembly with one specific set of
parameter values, and another product with another set. I also have a third
set of parameter values, which is only a 'maybe, what-if' set.
Clearly, when I use set 1, I can produce a complete pack of drawings and
models defining the first product.
However, when I want to produce another pack for the second product, I would
really prefer it if I still had the facility to refer to the models and
drawings of the first product. Similarly, when I do the 'What-If' analysis,
I need to retain the firm product sets of parameters too.
I envisage using the layout to do this. I could see me having three (or
four, or n) columns in the layout table, each having its own set of values
for the parameters in the layout. I would have another parameter ('SET'),
with a range of values (Product1,Product2,What_if3...Xxxn), each of which
would point the layout to the appropriate column of the table. Something
along the lines of 'IF SET = Product 2 THEN COLUMN = 2'.
Now, I am no programmer. I therefore come to a grinding halt when I get to
the above.
Is what I suggest possible?
Does it represent the most appropriate approach?
How is it accomplished? (Specific line-by-line answer here, please! :o))
If there is a better way, what is it?
Any constructive suggestions would be gratefully received.
WF2, M220
JWayman
(To:JWayman)
A bit of an update:
I have discovered how to create a parameter table in a Layout, with multiple
sets of values for each parameter.
I cannot, presently, display these values in a table on the Layout drawing.
I note the parameter table uses the Family Table editor, so I tried to do a
2D repeat region, with &fam_inst... etc. No good.
I can get it to fill a 2D repeat region with the values of one of the
instances, but I can't crack the 2nd dimension - the instances.
Any suggestions?
John
