Left-handed screw/thread
Steto
Dear PTC Community,
maybe this is trivial, anyway I ask: how to do left-handed threads in PTC Creo Parametric 9.0?
Thank you for your cooperation
Stefano Cristofanelli
BenLoosli
(To:Steto)
Symbolic representation of RH and LH threads would be the same. In your thread callout, just add LH after the thread type.
If you wanted to automate it a little, create a new hole file for the left-hand threads and modify the automated calout information to indicate LH.
21-Topaz II
(To:Steto)
When using a helical sweep feature there is an option for left/right hand rule.
Steto
(To:tbraxton)
Dear @tbraxton,
thank you for your quick support. However, I did not mean to makle a helical sweep for any thread (this would be graphically heavy and would not add any explicit information to the drawing), I just need to automatically define/label a thread as left-handed (so that the purchase dept. may provide the suitable screw/threaded bar).
Best regards
Stefano
21-Topaz II
(To:Steto)
It is typically dealt with in the hole callout/note with the suffix "LH". This is a US standard example; it may be different for ISO/EU standards.
Steto
(To:tbraxton)
Dear @tbraxton,
thank you for your reply.
Best regards
BenLoosli
(To:Steto)
Steto
(To:BenLoosli)
Dear @BenLoosli,
thank you for this hint, for me it is solved.
Best regards
