Hi.
Is it possible to change Line style in drawing on na View with Section?
It seems like it can not be done.
The only way I can do it, is that I chane the View in a Draft Entitie. And than I change the Line style.
Domen,
set selection filter (bottom right corner of Creo window) to Edge option. Then select model edge in the view, press right mouse button and use Line Style option.
Martin Hanak
Still doesn`t work.
I have noticed that line styles work only when you use No hidden or Hidden line as a Display style.
If you display model as Wireframe, no line styles are used.
So it looks like when you create a view with Section, you can`t use line styles.
Has anybody else noticed this or am I missing some basic concept in creating Line Styles?
Domen,
when I change the view from Hidden to Wireframe then line styles set in Hidden view disappear, too. I don't know, why
. Contact PTC Support if you can.
Martin Hanak
