Mechanica optimisation study
JonathanHodgson
Gurus,
From time to time I try to run an optimisation study in Pro/M.
On this occasion it's fairly simple: minimise mass, stress limit
(max_stress_vm) 500 MPa, with two dimensions to vary. Previously it may
even have been just minimise stress with two dimensions.
Every time I try this I get the error:
"** Warning: Changing the parameters has produced invalid
model or geometry for the following parameter
values:"
and then it shows values which are only a very small change from the
model's current dimensions, and which regenerate fine if I put them back
into the solid model.
Then it spends ages
"Recovering from invalid parameter values by cutting
step size."
without really getting anywhere.
What am I doing wrong? Sensitivity studies work fine, but I feel I
should be able to give the problem to my computer and just let it go
away and find an answer!
Jonathan
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender immediately and delete this e-mail from your system. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of Ricardo (save for reports and other documentation formally approved and signed for release to the intended recipient). Only Directors are authorised to enter into legally binding obligations on behalf of Ricardo. Ricardo may monitor outgoing and incoming e-mails and other telecommunications systems.
By replying to this e-mail you give consent to such monitoring. The recipient should check e-mail and any attachments for the presence of viruses. Ricardo accepts no liability for any damage caused by any virus transmitted by this e-mail. "Ricardo" means Ricardo plc and its subsidiary companies.
Ricardo plc is a public limited company registered in England with registered number 00222915.
The registered office of Ricardo plc is Shoreham Technical Centre, Shoreham-by Sea, West Sussex, BN43 5FG.
Hi Jonathan,
Try changing from the default optimizer to the GDP method. This method seems to be more robust, but can take longer. However, since you only have two parameters, it shouldn't make much difference.
Rod Giles | Senior Design Engineer | Polaris Britain Ltd.
