Merging multiple assemblies into one whole model
ZM_10242308
7-Bedrock
So right now I am designing a model with multiple assemblies and each having their own constraints and connections. I want to ask if it is possible to assemble all of them to one final model? if yes will all connections and constraints of each assembly remain?
(To:ZM_10242308)
Maybe. You have not provided enough detail to understand the data set you are working with currently.
If you create a new top level assembly model you can then assemble all of the existing assemblies into this new top-level assembly. You may benefit from the use of a skeleton model in this top level to facilitate the placement of the components.
(To:ZM_10242308)
