I am using Creo 7.0.5.0 for testing and when I run ModelCheck, it generates a script error and will not display all of the information.
Error has occurred in the script on this page
Line: 544
Char: 9
Error: Unable to get property 'remove' of undefined or null reference
Code: 0
URL: <Creo load_point>/Common Files/modchk/templates_new/mctabrea.js
Continue running scripts: Yes or No
ModelCheck runs in Creo4 utilizing the same set of check, condition, spell, etc files.
Opening the HTML page for the ModelCheck run outside of Creo and I can see all of the check information.
I only get that error when displaying the information inside of Creo using the ie_browser by default.
I switched to the Chromium_browser and the error does not appear.
Another thing to change when we go live with Windchill 11.1 and Creo7.
You may check alternate browser (config option windows_browser_type)
Will it be possible for you to share ModelCHECK configuration files? That may help to look in this.
