Modify Spline Drag Handles
dgschaefer
21-Topaz II
WF5 M090
In prior versions, if a spline had one end constrained with an angle
dimension or tangent constraint but the other was not, you could not
modify the drag handles. However, if both were constrained or both were
free you could. In WF5, it seems that you cannot modify them unless
both are free. This is a serious limitation and a rather large step
backwards.
Am I missing something here?
Doug Schaefer
LinkedIn
Doug,
In sketcher mode, I can modify a spline using drag handles without any problem. As an example - two curve entities with a spline created in-between and made tangent on each end. I get drag handles when I choose Modify.
Bob Schwerdlin
Design Engineer,
Dukane Corp.
2900 Dukane Dr.
St. Charles, IL 60174
630-797-4974 direct
