Anyone know why I get these warnings when I open assembly? It's not a one time occurrence.
Creo 4.0 M020
WayneF
If you have access to the PTC Knowledge Base, please search for article CS21545.
Cause:
These messages occur during regeneration of a bulk component if difference is discovered between bulk template and bulk component
Resolution:
Message | Description |
New parameter <parameter-name> was added from template <bulk-item-name> | There is new parameter <parameter-name> in bulk template <bulk-item-name> that was not present during previous regeneration |
Driven by template <bulk-item-name> parameter <parameter-name> become user defined | The parameter <parameter-name> disappeared from template <bulk-item-name>. Parameter <parameter-name> is left on bulk component but it's value no longer controlled by bulk mechanism |
User defined parameter <parameter-name> become driven by template <bulk-item-name> | Similar to first message but the parameter with same name already present in bulk component, with it's value now now controlled by bulk |
Type of parameter <parameter-name> was updated from template <bulk-item-name> | Type of parameter <parameter-name> in template <bulk-item-name> have changed since last regeneration. It was propagated to bulk component parameter. |
Cause:
Resolution:
Amit,
Looking complicated. I shall relay this info to those who may have concern.
Wayne
