Not sure if it's a bug or feature?
gkrishna
2-Guest
In style feature how do you import and align images in trace sketches of style feature,problem is when you use fit with the dimension bar horizontally or vertically the "scale"* resizes too even when not locked.
Ideally i believe when you fit horizontally only and only horizontal scale should resize (when not locked),not the vertical scale. and when you fit vertically using vertical dimension bar only vertical scale to resize
So am i doing something wrong? or this is a bug or a feature.
(scale property which very end of the dialogue box)
Here is the image of what is happening before fitting the image and after it,i am not sure it should happen or it should not happen.(made a mistake in image text,it should be 2.2700 not 2.700,problem remains the same althought scales are changing)
Image below is of after doing the fit.
