I have a from/to table in my drawing for a wire harness. I'm editing the relations in my table, but the more relations that exist, they fail to show in the table for bundles. There's nothing wrong with the coding of the relations, as they work great for the wires themselves.
Side note: The harness info is pulled in from a Neutral File which defines several parameters either per connector or per pin.
If I delete the last two groups (and only have the first two groups) in my relations, then the bundled information displays correctly. However, if I add the last two groups, the information dissappears from my table for the wire sheaths.
Here are the relations:
/* Defined the length in inches and millimeters for the table
LENGTH_MM = harn_run_len
LENGTH_IN = harn_run_len/25.4
/* Defines the MAKE FROM MFG P/N in the table
PIGTAIL_CHECK = EXTRACT(harn_run_spool_mfg_pn,1,7)
if PIGTAIL_CHECK == "PIGTAIL"
if harn_run_cond_from_conn_mfg_pn == "REPLACE"
PART_NUMBER = harn_run_cond_from_pin_sig_mfg_pn
else
PART_NUMBER = harn_run_cond_from_conn_mfg_pn
endif
else
PART_NUMBER = harn_run_spool_mfg_pn
endif
/* Defines STRIP LENGTH
if harn_run_cond_from_conn_stripping_length == "REPLACE"
FROM_STRIP_LENGTH = harn_run_cond_from_pin_sig_stripping_length
else
FROM_STRIP_LENGTH = harn_run_cond_from_conn_stripping_length
endif
if harn_run_cond_to_conn_stripping_length == "REPLACE"
TO_STRIP_LENGTH = harn_run_cond_to_pin_sig_stripping_length
else
TO_STRIP_LENGTH = harn_run_cond_to_conn_stripping_length
endif
/* Defines REF DES
if harn_run_cond_from_conn_designator == "REPLACE"
FROM_REF_DES = harn_run_cond_from_pin_sig_designator
else
FROM_REF_DES = harn_run_cond_from_conn_designator
endif
if harn_run_cond_to_conn_designator == "REPLACE"
TO_REF_DES = harn_run_cond_to_pin_sig_designator
else
TO_REF_DES = harn_run_cond_to_conn_designator
endif
Is this a bug, or am I doing something inherently wrong?
