Open Simplified Rep/large asm
dbowles
I have created a few simplified reps in a large asm.
Purpose to keep unwanted models out of ram.
When initially opening the large asm, I do not see the selection for the
reps I have created, only after opening master.
There is a selection to open a subset, I would like the reps I created.
Any Clues?
Douglas Bowles
Electro-Mechanical Design Eng.
520.794.7817
Cell 520.490.9395
PGR 520.281.6146
StephenW
(To:dbowles)
Are you pushing the down arrow by OPEN? That is where the "open representation" is.
[cid:image001.png@01D0776C.3B6B3780]
Stephen Williams | Mechanical Designer
NOV Rig Systems
Offshore
6930 N. Eldridge Pkwy | Houston, TX 77041
T 832.424.6285
E -
National Oilwell Varco
nov.com/offshore
Connect with us on Facebook<">https://www.facebook.com/NationalOilwellVarco> | LinkedIn<">http://www.linkedin.com/company/national-oilwell-varco?trk=tyah&trkInfo=tarId%3A1405455811306%2Ctas%3Anational+oilwell%2Cidx%3A2-1-4> | Twitter<">https://twitter.com/NOVGlobal>
The information contained in this transmission is for the personal and confidential use of the individual or entity to which it is addressed. If the reader is not the intended recipient, you are hereby notified that any review, dissemination, or copying of this communication is strictly prohibited. If you have received this transmission in error, please notify the sender immediately.
dbowles
(To:dbowles)
No, I did not see the pull down. problem solved.
Thanks!
Douglas Bowles
520.794.7817
Cell 520.490.9395
PGR 520.281.6146
