Is there a list of description options somewhere for CP4 M010?
Or is it possible to export config options with the description included?
Config option in PDF format can access from File > Help > Reference > Configuration options
OR it (configoptions.pdf) is available under installation directory of Creo 4.0\datecode\\Common Files\help\reference\pma\usascii
I use Olaf Corten proesite to find config options. He lists hidden options also, although they typically don't have descriptions as to what they are used for.
There is a config.pro table downloadable as a CSV file on the PTC web site under Creo 4 documentation.
