Hi, I wonder if anyone has come across this and knows of a solution or work around that can help. I have a pro/e drawing with the basic fonts from wildfire being used in the title block and a table. When the file is exported to PDF, DXF, DWG , the fonts are substituted in adobe, and dxf readers to an indescriminate font. Therefore there is no control over size or location of the text displayed in the export file. If I stroke all characters in the export dialogue box, then the file size of the each a4 drawing sheet becomes approx 10Mb, however the fonts are shown as per Pro/E drawing. The difficulty I have is that I have a drawing of 100 + sheets, and pro/e crashes with the stroke all fonts, as it appears to run out of memory. So the question basically is this How can I get a drawing out of Wildfire 4.0, as created, in any other format (PDF,DXF,DWG). I have tried also with windows ttf fonts and this makes no difference. I have raised the issue with PTC, and so far no solution. Does anyone else have this problem.
