Parameter Entry not working in new template
tzych-2
I am trying to create a new template from a working form. In the form I am prompted for parameters when I create a new drawing. When I create a template from this form, I am no longer prompted for these parameter. I followed the instructions in the LMS lesson and entered &parameter_name when prompted for the parameter during the creation of the template.
I was finally able to get the template to work by opening an empty drawing, placing the drawing into template mode,  going to LAYOUT-->SHEET SETUP and clicking on format to browse for my format file. CREO should allow TEMPLATE MODE to be selected before creating a drawing.
The format I was using has drawing parameters in 2 tables. This may have cause the issue.
Timothy,
&parameter_name must be entered into table cell.
Martin Hanak
When the template is created the &parameter_name:D is entered into the cell.
Timothy,
I have found some info in https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS51521
Martin Hanak
When you start CREO to make a new drawing template the TOOLS tab to place the drawing in template mode is not available until format file is loaded.
Timothy,
it seems to me that in Creo Parametric 2.0 M070 everything works well.
  1. I created prt0001.prt containing mypar (value=mytext)
  2. I created frm0001.frm containing table (the cell contains &mypar)
  3. I created drwtemplate.drw - I activated Tools tab and clicked Template icon, then I changed A4 size to frm0001
  4. I created drw0001.drw using prt0001.prt and drwtemplate.drw
See uploaded data.
Martin Hanak
Timothy,
to replace a format, you can also click SIZE tag at the bottom of the graphics area.
Martin Hanak
Thanks for the tip.
