Some of you might think that I might be crazy and you might be correct. I am currently building inspection sheets into my drawings. Because of the issue in regards to using a dimension twice, I build my inspection sheets outside of the drawing. I then import the inspection sheet as shared data. This is working very well for me. I want to take this process a step further. I would like to assign a word a parametric value "d100". I will keep these words in their own folders. The words that I am adding to the tables are the tools used for inspection. Any ideas?
