Situation: I 've updated some features in my assembly and after regeneration, one of my part stay colored in red...
Model is in ''Green light status'' and work well, only thing is the part misteriously stay in this '' red state''.
-and that's not the color assigned to the part.
thanks for your help/comments
Hi Francois,
I think while updating features of assembly, The assembly constraints of the part is lost, please check whether the part is fully constraint, if not reconstraint it, hope it will solve your problem.
Wajid
Hi Syed, thanks for your answer,
It seems that after couple of regeneration of the assembly, the mirrored parts were assigned an additional color, ''red''in this case.
So, the only thing to do is to remove the second assigned color.
I still wonder if this is a parameter of Proe to highlight that the part is a mirrored entity of another one....and why this second attached color is shown instead of the primary one.
thanks again for your support
Best Regards
