Pattern Feature
DieselPig
Pattern Feature
Morning All
Creo will not allow me to pattern the impeller blade of the attached. I see a few historical posts of something similar, any tips or advice?
see my solution ... I am not sure if it is the right one.
Hi Martin
One too many vanes but correct!
Thank You.
Dale_Rosema
(To:DieselPig)
Phil Szarko
Don't forget to mark Martin answer as correct for those who come across this thread to learn about patterning.
Thanks Dale - great tip!
Thank you Phil Szarko‌ for taking action.
Thank you Martin Hanak‌ for the solution.
Best,
Toby
